| Notices |
| Monitors LCD, CRT, plasma and beyond...chat about it here |
Thread Tools |
#1 | ||||||||||||||||||||
New Member
Just bought the HP w2207h with VGA input and HDMI. I am using the ati radeon 3870 video card, which only has 2 DVI outputs. I tried using a DVI to VGA converter, but when i set my resolution to 1680x1050 (recommended), the monitor automatically adjusts and moves the image about 3 inches to the right and a half inch down. Manually moving the image with the monitor will not move it over far enough, and i cannot move it vertically at all. I have been thinking about using a DVI to HDMI cable, but am not sure if that will actually fix the problem. Any help on what i can do to fix it or will the DVI to HDMI cable work? ![]() Thanks |
#2 | ||||||||||||||||||||
New Member
Forgot to throw this in, I have done everything i can think of with the catalyst control center in moving the image...hope this helps.
#3 | |||||||||||||||||||||||||
Admin
The 2207 has no DVI output?!?!?! Seriously??? Only VGA and HDMI?
#4 | ||||||||||||||||||||
New Member
Yeah, i know it is kind of rediculous... 2207h only has vga and HDMI.
#5 | |||||||||||||||||||||||||
Admin
Brutal (no offense).
A standard install in Catalyst shouldn't create this issue, and fixing it manually will only move the picture a bit. Sounds like a setup/connector issue. It's worth a try to get an HDMI, make sure you have a DVI/HDMI converter for your 3870 though. |
The following user thanks Skyguy For this above post:
Bulburt (28-10-2008) |
#6 | ||||||||||||||||||||
New Member
Yeah, i will give it a shot also, i may also try using a DVI cable instead of a VGA cable with the DVI/VGA converter. Don't know if that would make much of a difference, but it is worht a shot, i have used the converter before, but never the converter on the video card, it has always been at the monitor end...we will see, thanks!
#7 | |||||||||||||||||||||||||
Admin
Definitely try that first!!! VGA/DVI is usually your best best. If not, the HDMI.
Good luck, let us know how it goes. ![]() |
#8 | ||||||||||||||||||||
New Member
Will do, thanks alot for the input. And for anyone reading this....
PAY ATTENTION TO WHAT INPUTS A MONITOR HAS...i didn't...*smack forehead* DOH |
#9 | ||||||||||||||||||||
New Member
DVI<>HDMI cables worked...thanks for the help!
#10 | |||||||||||||||||||||||||
Admin
Awesome, glad we could help!
| Bookmarks |
| Thread Tools | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Asus Rampage Extreme Problem..... | kaganader | General Hardware | 28 | 18-12-2008 17:25 |
| Overclock and PSU Problem need advice? | DDesign | CPU Overclocking | 1 | 04-10-2008 20:12 |
| An interesting problem in Vista | rosy0123 | Operating Systems | 1 | 14-08-2008 18:36 |
| PureOC rss feed problem now fixed | News Team | Hardware News | 1 | 16-06-2008 17:47 |
| My problem. | reQuiem | CPU Overclocking | 10 | 02-06-2008 23:50 |
